250 Adjusting xenons for use abroad
Discussion in 'Electrical & Interior - Security, ICE, Wiring Loom' started by Matt W, Nov 26, 2015.
  1. As per the title, is there a way to change these for when I go abroad (Nurburgring 24hours :wink: )
    or do I still have to get a silly headlight beam adapter?
  2. Unless anyone knows otherwise I'm pretty sure it's a case of sticking those silly beam adapters on mate. I had an Astra with adaptive xenons very similar to the Megane and those could be switched from RHD to LHD very easily. I was hoping the Megane would be the same but I couldn't find anything in the manual or online so had to do it the old fashioned way.
  3. Yeah more then likely need stickers, I've seen older stuff usually BMW's with a simple switch on the headlamp to alter the reflection
  4. Usually most modern cars have a flick tab type thing inside the headlight (behind the cover) which you just flick over and it moves the kick up from left to right. Not sure if the Megane has it though. You would be more likely to have it with having the xenons than someone without id imagine.
