ABS Sensor
Discussion in 'Suspension, Brakes, Wheels & Tyres section' started by Danp, Sep 1, 2014.
  1. Hi guys,
    how easy is it to install one of these on a 225? Front left is the issue. Here is the part I have bought, hopefully the correct part.
    8200506304
  2. Just take the wheel off and clip the new sensor in, piece of piss mate
  3. Ok thanks I'll give it a go.
  4. I replaced my front left one a couple of months ago as I had warning on dash, easy to identify you can follow it from the back of the hub all the way round the suspension up inside the arch lining - piece of p**s to do only took 5 mins. I wouldn't completely remove the old one before putting the new one in as there are a lot of places they clip in and a lot of moving parts for a badly fitted sensor to chafe or get caught, I unclipped the old one up inside the arch lining, plugged the new one in and then followed the old one round unclipping it at every spot & clipping in the new one to ensure it fit exactly like the old one.
