Hey guys.. i managed to fix the issue with my meg, it was the drive shaft that broke. So i fixed it monday.. and i drover home and didnt see a road hump and went over it quickly.. the moment i did that the abs and esp light came on and it says asr fault on the dash. I had it at a mechanic and he cleaned the abs sensor. And said i should do tracking and balancing on the wheels. But im sure its more than that. Any ideas whats wrong guys? What can i do to fix it? Do i need a new sensor? Thanks in advance.
Air bag and service light is on.. i dont even know if there are any airbags in there. As it it a car d had someone hit the passenger doors. But it was repaired. And the abs light and esp come on after 10 mins driving.. or if you rev it hard and the wheels spin then it immediately comes on
Hopefully just a loose plug first thing to try is re plugging them in under the seat that sometimes turns off the service and airbag light. ESP and abs light coming on most likely broken connection in abs wires.
Ok how far is durham from london? I can drive down and if you can sort it all in one day id be more than happy. ??
About 5 hours mate. Your welcome to book in mate but will be about 2 weeks mate I'm up to me eye balls at the minute.
