A few questions
Discussion in 'Megane Discussion' started by Project 1200, May 17, 2021.
  1. Firstly what size hole should I cut in the front strut towers in order to be able to adjust the camber settings on coilovers.
    What shims should I order for improving the rear geometry for track.
    Thanks in advance
  2. ianplymouth
    Mine were about 76mm from memory, as for the shim plates i don't know as they were done for me when my BC's were fitted.
  3. Hi Tony,
    Need to get the car 4 wheel aligned to work out what you current rear camber is. Mine was 0.40°, so ordeed a couple of 60° shims. ( 1.40° )
    Kev.
  4. Cheers for the advice
  5. Cheers for the help.
  6. Cheers ian
