R26 630cc injectors and fuel gauge calibration
Discussion in 'Mechanical - Engine, Gearbox, Exhaust etc' started by Dale1uk, Oct 26, 2017.
  1. I bought my modified LY R26 a few months ago. Unfortunately for me the previous owner decided not to tell that the fuel gauge doesn't read true due to the 630cc injectors it has fitted, and well, I guess you can imagine what happened to me....
    Now searching the net I see that quite a few years ago only Paul at RS Tuning had sussed out how to calibrate the fuel gauge to read true with different injectors. Is this still the case, or can most tuners do this now?
  2. Daz
    I didn't even know this was a thing!
    Mikey4410 likes this.
  3. matt e
    Mines fine? Mapped by engine dynamics.
    I can't see how fitting bigger injectors would throw the fuel guage out and it's done by resistance in the tank with the float arm
  4. That's exactly what I thought but apparently not. Will dig up the posts I found.
    matt e likes this.
  5. Here's a couple of points from the RS Tuning website:
    "Injector scaling and fuel gauge/consumption for ANY injector size with or without fuel return"
    "Don’t spend weeks or months on end going back to your tuner for map tweaks when your fuel gauge doesn’t work or the ECU has learnt a fuel trim, do it once and do it right!"
    Page here: https://www.rstuning.co.uk/shop/megane-225-r26-custom-remap/
  6. For reference my car had its 630cc injectors fitted back in 2014 and was remapped to suit at the same time. Injectors were supplied mapped in by K-Tec
    Seems like this could be an old problem. @matt e does your fuel consumption and range read correctly on the dash display?
  7. matt e
    yeah, what was it reading when you ran out of fuel?
  8. Over 1/4 of a tank and iirc 100ish mile range.
    Had definitely ran the tank dry, my mate came to the rescue with a 5l jerry can and it started straight away and took another 55l to brim it
  9. Yeah common problem most specialists can do it properly now though.
    Its down to the shape of the fuel tank and the ecu relying on calculations once its under half a tank as the float is no longer accurate IIRC
    Sent from my FRD-L09 using Tapatalk
    Dale1uk likes this.
  10. Sorry should have said common problem years afo!
    Dale1uk likes this.
  11. Thanks, thought it must have been an old problem as all the treads relating to it are from a good few years ago.
    99% certain I'll be going to RS Tuning to get the map checked and tweaked anyways but it's always good to know I've got other options.
  12. cgrautomotive
    cgrautomotive RSM Trader
    The fuel gauge measures fuel used (in theory) rather than the using the sender in the tank, so with 630's fitted you use more fuel per ms of injection compared to the factory injectors so the fuel runs out quicker than the gauge thinks. It uses the sender in the tank when you fill up to reset the gauge.
    Quite common with 630's that haven't been mapped properly, as mentioned most decent places can set the fuel calibration map up without issue, including ourselves :blush:
