500bhp monster
Discussion in 'Megane Projects' started by Nathan Rees, Dec 6, 2023.
  1. Wossner pistons
    PEC Forged Rods
    Ported & Polished Head
    Balanced Crank & Flywheel
    Catcams Cams 402
    Supertech Double Valve Spring Kit
    Supertech Valves
    ACL Big End Bearings
    1000cc Bosch injectors
    OEM Main Bearings
    OEM Thrust Bearings
    OEM Gasket Kits
    OEM Timing Belt & Waterpump
    OEM Dephaser
    OEM Radiator
    AEM Water Methanol With Controller
    NGK Motorsport 9 plugs
    Power:
    Pro Alloy Intercooler
    Pro Alloy Turbo Cooler
    Garret G30 660 Turbo Kit
    Nortech Tubular Manifold
    3" Milltek Exhaust
    3” Downpipe
    Turbo Smart External Wastegate (GEN v compgate 40)
    Braided Fuel Lines
    ITG Induction Kit
    Bosch Flow Matched 1000cc Injectors
    Turbosmart Fuel Pressure Regulator
    OBP Swirl Pot
    044 Fuel Pump
    Surge Tank
    Pure Motorsport Aircon Delete Kit
    Mapped By EFI -
    Low Boost 375BHP
    High Boost 500BHP
    autronix, ~Shaun~ and ianplymouth like this.
  2. It is a monster in the right hands :laughing::laughing:
    Nathan Rees likes this.
  3. Thanks mate
  4. Must be undriveable on anything other than a perfect dry road/track :tearsofjoy:
  5. Its not really, i drove it around Oulton Park in the snow on full power, also did a good few laps at Anglesey on a very wet day, was fun
  6. I was running an open diff at 350bhp and it would spin up at 100mph in the wet :tearsofjoy: Really hope the diff drastically reduces it!
  7. it does and did, was really surprised how well the diff worked, i never felt the diff in my 265 work like that, but i can feel the diff in my 250 work like his does, once my monster is built we will see how they compare
    Agreen and Nathan Rees like this.
  8. She’s even better on slicks
  9. How is it you're limiting the boost? Do the 3rs have another ecu setting built in, or are you running a separate boost controller?
  10. Animal any pics
  11. I own this car now , the guy before me hadn't had it long , went to the ring , on the journey home it lost compression on No4 cylinder , sold it as it was and I had it delivered to me on it's way back on a recovery lorry , camera down the bore is showing a melted piston , so engine is coming out to see the extent of the damage , hopefully the head it ok , and it's just taken the piston out , and the bore will clean up , or will fix with a rebore.
    It's looking well used , and not looked after now , turbo cooler looks like it been frozen and blown up , the intercooler is looking tatty , the airfilter has half missing , turbo feels good , just ordered a new intercooler and turbo cooler , will start ordering engine bits once it's stripped and I know what's wrong
