4th gear and 5th gear judder ?
Discussion in 'Mechanical - Engine, Gearbox, Exhaust etc' started by geegreen, Mar 5, 2016.
  1. Need some help chaps when I hit Boost in 4th or 5th gear I get a horrendous judder and the car struggles to get going ..... Any ideas what this could be ? I run the car on super unleaded and I've check the filter on the sender unit and it's clean as a whistle ?
  2. Misfire probably. Spark plugs, coil pack ?
  3. Mine started doing this. Had them change the plugs when doing the clutch and problem sorted. Well overdue job as there was a 3-4mm gap when they removed the old ones, and black with it!
