250 radiator cooling fan not working
Discussion in 'Mechanical - Engine, Gearbox, Exhaust etc' started by dale.groves, Jul 19, 2016.
  1. Hi guys,
    Coolant temp is sitting high when stationary, and cooling fan never seems to kick in. And common issues? I know hot running is a problem with 250s but it's on the verge of overheating even when pooling around.
    The minute I'm on the move, it calms down.
    Any help appreciated, Dale.
    Sent from my HTC One_M8 using Tapatalk
  2. Easy test to work out what's wrong...
    There will be a temperature sensor on the side of the radiator (or on the radiator hose pipework). Disconnect the wiring harness from the sensor and bridge the gap with a length of cable/wire... If the fan starts, it's a broken temperature sensor... If the fan doesn't start.. It's a new fan.
  3. Awesome thanks
