225 Trophy wheel offset.
Discussion in 'Suspension, Brakes, Wheels & Tyres section' started by Craig_B, Nov 27, 2015.
  1. Looking into getting another set of wheels mainly for track.
    I've come across some normal 225 wheels and it states the offset is 65? I'm not sure what the offset is for trophy wheels
    Would these be ok to use on my Trophy?
  2. Yeah they'll be fine.
  3. Sorry to tag onto this but what is the offset of the r26 alloys, is it the same? And pcd etc?
  4. can i get away with 45mm offset wheels on a 225 ?????
    8j wide
  5. anyone :confused:
  6. Bebop wheels (R26, Trophy, Cup...) is 8x18 ET68. Fitting ET45 ones means 23mm more displacement per wheel (to the outside)
  7. I run 55, they fit well. You could probably go up to 50 with no problems.
