225 Short shifter
Discussion in 'Wanted' started by Dutch, Mar 10, 2021.
  1. Been trying to get a hold of Phil Watkins to try and sort a short shifter for my 225.
    anybody have one laying around they don't need?
    thanks in advance
  2. ianplymouth
    If it is a 225, then you can do the job yourself easily
    There is no machining to be done, its just drilling a hole and inserting another ball stud.
  3. matt e
    PH1
  4. phase 1 linkages and actuators are only on 2004 and 2005 cars.
    The phase 1 actuator had a twin spring design,with small linkage.
    Its actually the sweetest shift of all mk2 gearshifts when fitted with the shortshift...
  5. i guess ill give it a go myself then, thanks for your help guys. ill be sure to look for a guide.
    i did see on already for the later design actuator, im guessing its not to different from that?
  6. ianplymouth
    Oooppps
    Thought it was the same for all 225's, thanks for the update.
    Never to old to learn :tired::tired:
  7. upload_2021-3-11_18-50-20.png phase 1
    matt e likes this.
    shortshift phase 2 linkage...note the ballstud has been moved,and a section machined flat to except the ballstuds new location..
    matt e likes this.
