I have a late 2005 225. I need some rear brakes fairly soon, but there seems to be a lot of different ones out there with different sizes. For example, I found these http://www.eurocarparts.com/ecp/c/R...ab6867afb4f5d54f38be43fdc71ee37a18b6ed&000027 Would they fit mine? And for pads, would these fit? http://www.eurocarparts.com/ecp/c/R...3b9552e4d78d8d23a955ea84c43dd87930fb41&000036 It seems a minefield with the differences between ph1 225, phase 2 225, cup, r26,.... Help!
Oh and also can someone advise me which rear hub diamater a phase one 225 so I know which discs i can choose from.
I've not long replaced the rear brakes on my PH1 225. The wheel bearing is 25mm as mentioned above. I bought genuine Renault discs and pads from Ads on here (the discs were cheaper than those Pagid ones!). As for the pads they appear to be the correct shape as they look like mine. The PH1 rear calipers differ from PH2 I believe hence the different pad shape.
I spoke to G172 and Ads two weeks back when I ordered rear discs and pads. Ads was comfortably cheaper!!!!!
