225 Rear Discs
Discussion in 'Wanted' started by AlexGSi2000, Aug 17, 2016.
  1. After a pair of rear discs for a 2005 Megane 225.
    Dont mind if they are used, as long as they have life left in them.
    Thanks.
  2. Better getting new ones as the bearings are pressed into the discs on the rear.
  3. Thought as much - thought I may be able to get away buying used.
    I have looked on ECP for new ones, its given me the choice for plain and drilled (cup) discs, as far as I can see the disc dimensions are the same - would I have any issues using plain discs?
    The car is mainly used by the other half and occasionally by myself, so is rarely driven hard - let alone hard enough for the rear brakes to make use of the additional cooling.
  4. Renault parts direct or George will sort you out mate.
    As for the drilled/plain discs I recently replaced the discs all round on my 225 Trophy & opted for plain discs.
  5. Thanks for your advice Stevo, appreciated.
