225 225 rear brake caliper removal. what tools ?
Discussion in 'Suspension, Brakes, Wheels & Tyres section' started by pervertedmonk, Mar 24, 2015.
  1. Hi.
    Going to attempt to free up both my rear calipers before its mot next month. just thought id check what size spanners i would need and if i need a star or torque socket to undo the cradle ?
    i have the rewound tool.
    Or am i wasting my time on these and best fit a new set. it seems a common fault with these. my fault for not using it much..
  2. 13mm and 15mm spanners. Simple as that. I couldn't free mine off and ended up during out for a new pair
  3. cheers for that fella. thought id have a bash first before i have to do the dreaded. where did you get your replacement calipers from ?
  4. Just a local motor factors. Think I paid £70 each or something like that.
  5. Ive just replaced the pads on mine, the caliper was attached with 2 x18mm bolts.
    Sent from my GT-I9100 using Tapatalk 2
  6. Whaaaat? 18mm? That's not right
  7. I definitely used an 18mm spanner on mine, and it fitted!
