had a couple of people message me on facebook asking if i plan on doing any more, so if there is enough people wanting one ill sort some more out the kit comes with everything needed to move the battery from under the bonnet to the spare wheel well. all the cable would come precut to length and have the connectors pre clamped and all the fixings. it would also include a new metal powder coated ECU mount which has the option to run a oil catch can, if that option is chose i can supply the catch can and fittings for it. relocating the battery in the boot allows you to easily run the air filter to under the headlight for cooler air. kit includes powder coated ECU bracket 25mm2 power cable 25mm2 earth cable fuse holder holder for engine bay fuses battery box (fixings to hold to boot floor included) fixings for new ECU bracket oil catch can kit £245 posted Oil can fitted by matt eaton, on Flickr Battery connection box by matt eaton, on Flickr 5
