225 225 Megane vibration, gearbox??
Discussion in 'Mechanical - Engine, Gearbox, Exhaust etc' started by Harry keane, May 28, 2024.
Tags:
  1. I've got a stubborn issue with my 225. At around 65-70 I have a bad vibration from the floor but only when accelerating. Can also feel a slight wobble low down when in second gear at around 1700rpm. Car also sort of jumps from first to second gear with almost no input. I've had a clutch recently, driveshafts and engine mounts have been done. Any help as to what this could be would be amazing!
  2. Gearbox issues at a guess. Had minor vibration/slight wobble on low down acceleration on our 225 which dissappeared when changing to r26 gearbox.
    Did you change dmf when doing clutch?
