225 225 clutch bleed
Discussion in 'Mechanical - Engine, Gearbox, Exhaust etc' started by iiPaul, May 21, 2017.
  1. So my megs just been put back together with s new clutch and slave and I've bled the system using the guide on here (unclip the main feed one notch and keep pumping the peddle back and fourth) however my clutch only works just under half way down, and I can't select any gears when the cars running, but can when it's off.. is there any other ways to bleed the clutch?
    I primed the slave before fitting
  2. Anyone help please [emoji85]
  3. i wedged my pedal down overnight , take the cap off ,as i had same problem, it sorted it for me, good luck.
    iiPaul likes this.
  4. I'll give it a try thanks [emoji1303]
