225/230 megane hub swivel bearings
Discussion in 'Suspension, Brakes, Wheels & Tyres section' started by RMS225, May 1, 2015.
  1. Hey all doing a front end refresh and wanted to know of anyone can give me info on getting the hub swivel bearings separate as ren sell them with a hub
    Thanks all
  2. There Is a sticky called oem suspension components or something similar that has the part number and supplier for bearings in it
  3. Sorted got the bits here's what you need
    AFAIK bearings are INA BK4520 + bearing insert INA IR404520 + oring seal 52mm/4m
  4. I've got a bearing I can sell you for £30 delivered if you want it?
  5. Is it for one side or both sides Thanks
  6. Only 1 sure I'm afraid
  7. Where did you get the bits from? Have got bk4520's but didn't realise I needed the other bits! Glad I haven't started stripping it down yet!
  8. Got them from Derby bearings bud very helpful and have stock
