Hi guys need some help recently had my near side bottom ball joint changed as well as wheel bearing. But since it was changed car is pulling left under braking have had calipers out and looked at they are good also got 2 new front tyres on so I am having problems figuring out what is causing the problem...any help would be much appreciated.... Cheers..
Have ya had the brakes checked in brake rollers and weather there's any imbalance. If all that is OK and in tolerance. It's git to be suspension related I.e worn suspension bush or support bearing so on buddy.
This will be a steering arm bush or roll bar bush maybe even the track rod end that was compensating for the play in the swivel joint now that has been replaced. Just to add was the other side swivel n bearings checked ?
If it's only done it since the work has been done I'd be questioning if the job was done right or if it's the correct parts. Jack the side up you had done and check for play.
