18" RSR tyre pressures.
Discussion in 'Suspension, Brakes, Wheels & Tyres section' started by imprezaworks, Nov 4, 2015.
  1. What's the correct ish tyre pressures for road use?
  2. I use 36 front 32 rear.
  3. Cheers Andy. Was going to try 34-32 but will go with that. Think they are 30 at the front, not sure on the rear.
  4. 36 and 32, spot on. Thanks.
  5. for r26r, it is stated 34psi front and 30psi rear.
    i guess for non .r 32 psi to compensate the extra weight for the rear is probably right
