Renault Megane 3 RS – issues after clutch, flywheel, and slave cylinder line replacement
Discussion in 'Mechanical - Engine, Gearbox, Exhaust etc' started by Kamil3RS, Oct 9, 2025.
  1. Hi everyone,
    I need some advice because I’m running out of ideas.
    Recently, on my Megane 3 RS 273KM (75,000 km), the following work was done:
    • replacement of the clutch (OEM Renault),
    • replacement of the dual-mass flywheel,
    • replacement of gearbox oil,
    • replacement of the clutch slave cylinder hydraulic line (with a new stainless braided one, because the old one failed).
    The slave cylinder itself was not replaced, only the hydraulic line.
    The system was bled twice, and again later with fresh brake fluid.
    Sympthome after the repair:
    • With the engine off, all gears shift perfectly smooth — like butter.
    • With the engine running, sometimes gears go in smoothly, sometimes feel notchy or resist slightly.
    • 1st gear occasionally won’t engage (especially when stationary or in traffic), but if I release and press the clutch again, it goes in fine.
    • 2nd gear sometimes gives a slight grind when shifting.
    • 3rd gear can lightly “chatter” or “graunch” if I shift fast or aggressively.
    • The clutch pedal feels firm, but consistent and without any clicks or jumps.
    • No fluid leaks, the line and slave cylinder are dry and tight.
    What I’ve noticed:
    • The issue with 1st and 2nd gear is inconsistent — sometimes everything feels perfect, sometimes it’s not.
    • After bleeding, there was some improvement, but not completely fixed.
    • When engaging reverse, the car occasionally jerks slightly, as if the clutch isn’t fully disengaging (same on the others gears).
    Someone have advice? Same problem? Thank you so much for help
  2. a suggestion.
    With the engine off, pump the clutch peddle half a dozen times and hold or wedge the clutch peddle down for around 10 minutes or longer if possible, then release the peddle.
  3. I tried that — kept the clutch pedal pressed down for about 20 minutes after pumping it several times. Unfortunately, it didn’t make much difference.
    After starting the engine, I tried engaging 1st gear about 15 times until it finally refused to go in. The same thing happened with 3rd gear.
  4. Assuming new DM flywheel + clutch etc installation is correct (?), the likely cause of your problem is air remaining in hydraulic circuit
    I used the syringe method when replacing my clutch line, and found it the best way to remove ALL air
    Might be worthwhile giving it a try
  5. You had same problem? Or made it preventively? I assumed the same about mounting whole equipments. On Friday I’m going to another mechanic. He will look on the other side. I will try Syringe methode next week and I will get back to you
  6. No one mechanic can do reverse bleeding xD Ehh god. One of them told me, that suposed to be clutch pump. What do you think? I can’t agree with him because clutch pedal is hard everytime.
  7. If you're confident there is no air in the hydraulic circuit maybe consider either the master or slave cylinder being the problem?
    Difficult to change the slave so maybe it's worth looking at the master cylinder??
  8. From ChatGPT
    Your symptoms point to a likely clutch engagement or hydraulic system issue, possibly compounded by gear synchronizer wear in the transmission. Here's a breakdown of what your observations suggest:
    Likely Causes
    1. Incomplete Clutch Disengagement
    If the clutch isn’t fully disengaging when the pedal is pressed, it can make shifting into gear difficult — especially:
    • 1st gear when stationary
    • Grinds when going into 2nd or 3rd fast
    You mentioned:
    "Releasing and pressing the clutch again lets it go in fine"
    This is a classic sign of incomplete disengagement.
    Even though the pedal feels firm and consistent, the clutch may still not be disengaging fully due to:
    • Slight air in the hydraulic line
    • A weak master cylinder (even if there’s no leak)
    • A sticky or dragging clutch disc, possibly due to:
      • Warped disc
      • Faulty pressure plate
      • Input shaft binding
    2. Hydraulic System Marginal Performance
    You said there are no leaks, and components are dry, which is good. But:
    • A lazy clutch master or slave cylinder can still fail to deliver full movement
    • Air in the system can cause soft or incomplete actuation, even with a firm-feeling pedal
    ➡️ A good bleed of the clutch system is inexpensive and worthwhile as a first diagnostic step.
    3. Transmission Synchronizer Wear
    The symptoms in 2nd and 3rd — grinding or graunching when shifting quickly — are typical of:
    • Worn or slow synchronizers, especially if the clutch is okay
    • This is more common in higher-mileage or aggressively-driven cars
    4. Transmission Mounts or Linkage
    Less likely, but worth checking:
    • Worn transmission or engine mounts can slightly misalign linkage or cause torque movement that affects smooth engagement
    • Shifter cable/linkage wear or misalignment can cause inconsistent gear feel
    Suggested Tests / Checks
    1. Clutch Drag Test (Simple DIY):
      • Engine off: Start in 1st gear, clutch pedal pressed.
      • Start engine with foot still on clutch:
        • If the car lurches forward, the clutch is dragging.
      • Or: try to shift into reverse (no synchro) while stationary — if it grinds, clutch isn’t fully disengaging.
    2. Clutch Fluid Bleed:
      • Even a small air bubble can cause symptoms like yours.
      • Flush and bleed the system to eliminate this as a variable.
    3. Check Clutch Fork / Slave Travel:
      • Have someone press the clutch while you observe slave cylinder travel.
      • Compare to spec or online videos for your car — short travel = incomplete disengagement.
    4. Transmission Oil Check:
      • Old or wrong-weight oil can affect synchros.
      • Check level and condition; consider replacing with a high-quality GL-4 gear oil (if applicable).
    ⚠️ Summary Diagnosis
    Symptom Likely Cause
    Smooth shifting with engine off Clutch disengagement issue
    Notchy or resistant with engine on Clutch or synchro issue
    1st gear hard to engage at stop Clutch dragging
    2nd/3rd grinding slightly Synchro wear or clutch dragging
    Firm clutch pedal Hydraulics may still be weak/airlocked
    ✅ What To Do First
    1. Bleed the clutch hydraulic system thoroughly
    2. Inspect slave cylinder travel
    3. Check transmission fluid
    4. Test for clutch drag
    If it persists after bleeding and confirming full clutch disengagement, it's time to consider:
    • Clutch installation check/redo (disc, pressure plate, maybe flywheel resurface)
  9. Little update:
    Mechanic changed clutch pump and pressure bleeded - no changes at all. Still gear occasionslly won’t engaged.
    After this, he changed also gearbox oil (unfortunatelly he mixed 2 75w80) and it’s better than before. It is still not perfekt but gears engaged when I push them stronger.
    What do you think?
  10. Gox
    Gox
    hello brother,did you solve your problem ?Because i have some similar symptoms like yours
  11. Not much, the problem resolved by itself (kind off). On February master clutch cilinder went dead. After this situation car went back to the mechanic who installed parts. It turned out that clutch (shield) and master cilinder were failure.
    For now I have new parts and the problem is still there. It supossed to be cold oil gerabox
