My 2011 rs250
Discussion in 'Megane Projects' started by Mikey mells, Sep 19, 2026.
  1. Mikey mells
    Mikey mells RSM Club Member
    Heya guys,
    I bought this lovely 2011 rs250 megane from sheffield on the 15 August 2026.
    It's only done 93,500 miles and has a full service history,two keys and drives lovely.
    I'm so happy with it.
  2. Mikey mells
    Over the last few weeks i have sorted a few items on a list I have.
    * Given the car a good wash including every single door shut,thoroughly hoovered the car,wiped down interior etc.
    * Replaced a driver door bulb.
    * Polished the headlights as they had a little haze on them.
    * I have claybarred the car which took 4 hours to do.
    * I have fitted new boot gas struts as the old ones were rusting and looked horrible.
    Have many other bits and bobs to sort as I want the car to a very high standard.
  3. Mikey mells
    On the 5.09.26 I went about fitting two new rear cup dampers,and I also cleaned the wheel arches area. Looking pretty clean under there.
  4. Mikey mells
    On the 15.09.26 I took the car to Andy at engine Dynamics to have the current map checked and makesure it's fueling safe etc etc.
    It got a clean bill of health and some good power figures so it was worth doing.
  5. Mikey mells
    On the 19.09.26 I went about fitting new brake lines as the old rubber ones are a few years old now.
    Very luckily it went OK and the unions undid without issue.
    The colour of the brake fluid says it all,it meant to be light transparent yellow!!
  6. Mikey mells
    I also whilst doing the braided lines,used a "GRAMS" brembo caliper rebuild kit.
  7. Mikey mells
    22.09.26 I had two really good used michelin ps5s fitted.
  8. Mikey mells
    26.09.26 Today I fitted new ngk spark plugs (gapped to 0.60mm) along with new pencil seals.
    I fitted a new genuine expansion bottle as mine was discoloured and had a split in it.
    And lastly I fitted a rear wiper bung as i got rid of the rear wiper unit.
  9. Mikey mells
    The last few days I have started renewing all four of the engine mounts,starting with top drivers side and lower gearbox mount.
    And I resprayed the rear renault badge ,and painted the front one also.
    Muxa likes this.
  10. Mikey mells
    Today i went about replacing the gearbox mount ,but found it had recently been replaced and really didn't need doing so i have sent the new one i purchased back.
    I have finally got round to doing the m12 upgrade bolt mod on the gearbox mount,it was quite straight forward really and I threadlocked the bolt as I don't want it coming loose. I have also put a mark on top of the bolt so I can check for any movement.
    I also got round to running a vacuum line into the cabin for a boost gauge, I drilled and then fitted a tidy grommet for the vac line to pass through safely. I spliced in and t-pieced right before the recirculation valve as my vacuum feed.
