Oil leak - oil feed pipe to turbo. RS250
Discussion in 'Mechanical - Engine, Gearbox, Exhaust etc' started by pauljoecoe, Feb 14, 2025.
  1. Got a leak at the join from the oil feed pipe into the turbo. I think it's the 0 ring so I ordered the kit from Renault but the ring is different. Mines flat and black. The new one is green and rounded.
    To dealer has ordered in the whole pipe to see if the ring comes on the pipe but if that is the case it will cost me £60.
    Anyone had this problem and found the correct O ring?
  2. The O ring is for the pipe that goes into the block at the back of the starter motor, if its a standard turbo, then you should have 2 oval ish black gaskets, 1 for the pipe to turbo and the other is for where the short pipe (to the turbo) and the long pipe that goes to the block.
  3. Attached Files:
  4. Thanks for your replies.
    The O ring I need is the one at the end of the oil feed pipe going into the turbo. Renault cannot seem to find the correct one and think it may come as part of the pipe assembly its self.
    Just wondering if anyone knows how to source the correct O ring without buying the whole pipe.
  5. I have the same problem Renault are idiots I know a guy who was a top technician at Renault who's now on his own he stripped a turbo on a rs250 and the washer was black and flat he said the green o ring will not work
  6. Just had this issue, I used an Green o-ring from an old map sensor. You could likely use an old injector o-ring also.
    The end of the oil feed sits in a tapered hole, so the o-ring is mostly to allow minor pressure to be applied to keep it sitting tightly. Just be sure to use a decent viton type o-ring which handle heat well. Size is 14x8mm and about 2mm diameter.
