1. Battery is on its way out, is it better when is been run and the outside air temperature has gone up
  2. I have 2-3 months I have changed the battery they was 30 procent. Problem not solved :worried:
  3. Not fixed the car going under the 9 volt after start can any help me ?
  4. It's going to be your alternator then, voltage regulator, normally they go high voltage not low, but anything is possible.
    Is that 9 volts at the battery ????, there's nothing to say that your new battery is good, get it checked just to rule that out.
  5. Thank you wil check it my garage said under 9 volt but I dont know where hé checked
  6. I changend the body control unit 3 Months no problem and now is it back. Any help me ?
  7. The UCH is receiving too little voltage.
    Round 9 volt and thats why the lights turn on
