Wossner pistons PEC Forged Rods Ported & Polished Head Balanced Crank & Flywheel Catcams Cams 402 Supertech Double Valve Spring Kit Supertech Valves ACL Big End Bearings 1000cc Bosch injectors OEM Main Bearings OEM Thrust Bearings OEM Gasket Kits OEM Timing Belt & Waterpump OEM Dephaser OEM Radiator AEM Water Methanol With Controller NGK Motorsport 9 plugs Power: Pro Alloy Intercooler Pro Alloy Turbo Cooler Garret G30 660 Turbo Kit Nortech Tubular Manifold 3" Milltek Exhaust 3” Downpipe Turbo Smart External Wastegate (GEN v compgate 40) Braided Fuel Lines ITG Induction Kit Bosch Flow Matched 1000cc Injectors Turbosmart Fuel Pressure Regulator OBP Swirl Pot 044 Fuel Pump Surge Tank Pure Motorsport Aircon Delete Kit Mapped By EFI - Low Boost 375BHP High Boost 500BHP
Its not really, i drove it around Oulton Park in the snow on full power, also did a good few laps at Anglesey on a very wet day, was fun
I was running an open diff at 350bhp and it would spin up at 100mph in the wet Really hope the diff drastically reduces it!
it does and did, was really surprised how well the diff worked, i never felt the diff in my 265 work like that, but i can feel the diff in my 250 work like his does, once my monster is built we will see how they compare
How is it you're limiting the boost? Do the 3rs have another ecu setting built in, or are you running a separate boost controller?
I own this car now , the guy before me hadn't had it long , went to the ring , on the journey home it lost compression on No4 cylinder , sold it as it was and I had it delivered to me on it's way back on a recovery lorry , camera down the bore is showing a melted piston , so engine is coming out to see the extent of the damage , hopefully the head it ok , and it's just taken the piston out , and the bore will clean up , or will fix with a rebore. It's looking well used , and not looked after now , turbo cooler looks like it been frozen and blown up , the intercooler is looking tatty , the airfilter has half missing , turbo feels good , just ordered a new intercooler and turbo cooler , will start ordering engine bits once it's stripped and I know what's wrong
I have a fully forged Megane 3 RS 250 equipped with a large Kuro turbocharger (Garrett-style, ball bearing, internal wastegate), wossner std pistons, a tubular exhaust manifold, a 13-row oil cooler (Setrab), 850cc injectors, and a Wagner intercooler, among other upgrades. I am currently running 26 PSI of boost, producing around 380 WHP. However, on some occasions I experience knock events, which can reach a value of 1 or 2. Then, when I accelerate again, the knock levels drop until they eventually disappear. Has anyone experienced similar detonation issues on the F4RT engine?
