Megane RS PH2 265
Discussion in 'Mechanical - Engine, Gearbox, Exhaust etc' started by robson, Oct 28, 2024 at 5:55 PM.
  1. Hi!
    Two quick questions. ECU is EMS3110.
    1. Does the car need to be cool (not hot at least) to connect to ECU and change anything in the map/tune?
    2. Is changing the idle RPMs as easy as changing given values (e.g. 750 -> 800)? Or do you need to change other parameters to bump idle RPMs higher?
    Thank you in advance!
  2. autronix
    autronix RSM Club Member
    1. no
    2. there are several places that you need the change the idle.
    this for the EMS3125 but 3110 is similar to an extend. do you have .ols for it?
  3. autronix
    there are 2 main maps but another one needs to be touch also.
    this is the main one + the RS mode one. I have mine set @ 800 rpm
    RS mode
  4. Never mind, I've made a throttle adaptation via PyClip and the car won't start now , soooo ECU has already been sent to a great tuner who will fix the issue as well as increase the idle rpms to 850 on normal mode to make it run smoother.
    Thanks for the answer!
