R26 Scuttle panel
Discussion in 'Exterior & Bodywork' started by Geoff230F1, May 19, 2019.
  1. Good evening all, hope you've had a good weekend.
    I found that my drivers side carpet would get wet after rain or washing the car. I found the 2 drain channels were blocked and using a coat hanger and a bicycle outer cable managed to unblock them and the water drains away as it should now.
    The material panel below the scuttle/wiper panel is saggy as anything and the rubber will not mount to it any more. What have people done about this. The wiper panel just flaps about and I did think about siliconing it to the screen bur this would be a nightmare if i need a screen. Can this panel be ordered from Renault or is there another way?
  2. matt e
    i bought some metal heatshield and made my own
  3. Off the subject but what hard pipe kit is that matt? Looks huge!
    Sent from my SM-G960F using Tapatalk
  4. matt e
    its the gt performance one
  5. That looks good Matt. Do you have any info on where you got it from? I've seen your battery relocation kit. If I wasn't spending a fortune on just getting the car correct I would have one. Hopefully soon I'll have the available funds to order the kit. Do you think it would be possible to relocate the battery to behind the passenger seat?
    matt e likes this.
  6. matt e
  7. matt e
    yeah the battery can be moved to behind the paasenger seat, do you use yours as a road car or track? if road i would put it in the boot rather than behind the passenger seat
  8. Yes it is mainly a road car, yes youre right
