Y Reg Ph1 Clio 172 £2300
Discussion in 'Cars For Sale' started by hsustyle, Oct 7, 2018.
  1. hsustyle
    hsustyle RSM Club Member
    OK here goes
    Selling my ph1 due to doing more miles than ever so need something with cruise control and less special.
    I've spent more on this than my last one
    New work contract means I'll be doing a 300 mile round trip 2x a week, mostly motorway. I need more comfort and cruise control.
    Y reg
    128k miles
    8months mot
    Hpi clear
    Loads spend over last few months, receipts for everything, all mods listed are less that 4months old!
    drives Fantastic, no knocks or rattles. Pulls hard, haven't even bothered with rs tuner map!
    42 mpg over last 5k miles :smile: it's a motorway queen..
    Engine
    ITG filter in ph1 airbox (3clips), cold air feeds
    Oil catch tank (not fitted)
    182 manifold heatwrapped
    Ktec decat link pipe
    Matched inlets (not fitted)
    Exterior -
    Hid conversion. White not blue!
    Cup spoiler
    Ph2 rear bumper
    Fabia splitter
    15mm spacers front, extended wheel bolts
    Yellow fog film tint
    Ph2 light clusters in ph1 rear lights
    Oz f1, one has faint scuff
    ADO8R fronts 6mm
    Nangkang ns2r rear, 6mm
    Interior
    Ph2 dash, wired correctly
    Dashcam hardwired (already there when bought)
    Sony headunit, Bluetooth, aux in, USB in
    Modified scenic shifter with extended bar below& Yanoo stiff shift 3 (adjustable)
    Momo boss & dishes steering wheel
    Chassis-
    4x Cup dampers
    Grams springs
    Cup lower arms
    Camber bolts -1.4 degrees
    Tiny bit of Toe
    Whiteline rear arb
    Polybush ARB inner and outer
    Polybush Lower engine mount
    Polybush steering rack
    New gearbox mount
    New top engine mount
    New ball joints
    New track rod ends
    Transmission
    Yanoo brass bushes
    Yanoo gearbox end bush
    Brakes
    Braided lines front & rear
    Ebc bluestuff pads front
    (2L ATE 200 DOT 4fluid supplied)
    Good bits -
    LOADS of new parts in last 3 months with receipts.
    I have a Dropbox folder of receipts and PayPal invoices for parts to email to new owners)
    No rust on rear ARCHES or elsewhere, I've had mild surface rust treated, sealed and resprayed in rear arches, can send pics.
    Bad bits
    1 key
    Needs fob button pressed on starting for some reason otherwise immobiliser light stays flashing.
    Scratch on os rear, hardly noticeable, see pic
    Wheels aren't perfect but pass 10ft test
    Air con needs a regas
    £2500 with belts done
    £2300 as it is with genuine belt kit (worth £315)supplied as below for you to do yourself.
    Cambelt
    Dephaser
    Can seals
    Waterpump
    AUX belt & tensioner
    Type D coolant
    New expansion bottle
    Hailsham /Tunbridge wells
    Spares include
    2x hardly worn NS2R tyres
    Professionally matched inlets
    Box full of sensors
    Spare standard catback exhaust
    Oil catch tank
    Original induction elbow
    Ecu tray & fixing
    Sets of locking wheel nuts etc etc
    45074365241_b29fe9c411_z.jpg IMG_20181001_133352_747 by Amin Abdalla, on Flickr
    44057142215_42ab42dd0a_z.jpg 2018-09-28_03-37-28 by Amin Abdalla, on Flickr
    44251084425_5776e62341_z.jpg IMG_20181007_192111_521 by Amin Abdalla, on Flickr
    44440538694_9cb23459f2_z.jpg IMG_20181007_192111_524 by Amin Abdalla, on Flickr
    44251087215_0d87ffa17f_z.jpg IMG_20181007_192111_525 by Amin Abdalla, on Flickr
    30584596568_142a9732b1_z.jpg 2018-09-03_08-04-12 by Amin Abdalla, on Flickr
  2. hsustyle
    Sold
    imprezaworks likes this.
