R26 Will johnson gearstick mod
Discussion in 'Mechanical - Engine, Gearbox, Exhaust etc' started by Tomtomtom, Feb 6, 2018.
  1. Hi
    Hoping i am posting this in the right place
    My r26 gearknob had seen better days so orderded will johnson’s kit
    Comes with machined cone with m10 thread for standard gearknobs. Ebay £7 mine!
    Glue and modified lifter cone for reverse.
    Guides fairly easy to follow.
    Took a bit get the old knob off. Take cover off put screwdriver in hole . Tap , helps loosen it up
    Once off hacksaw where the metal steps down
    File and tidy up
    Chop down reverse lifter bit 10cms long
    Dry fit and make sure reverse works
    Chuck glue in reverse mod and the metal collar
    15 min at least
    I then tried to refit gator while it was a little wobbly
    Best wait a few hours
    Tidy up done
    Makes a massive difference to the feel. Bit sharper for changes.
    Much more positive
    Might look at his short shifter mod next
    Well engineered
    Tom
    Big Uno and Mikey4410 like this.
  2. Wicked write up dude.looks so good.
  3. I’ve been looking at these too, so how much shorter is the lever now then?
    And what gearknob have you got, looks good?
  4. Would this work with the mk3 as well?
    I've got a RS250 and have wanted to change the gearknob for a while.
  5. short shift is by far the best mod for a mk1/2 meganesport..transforms the quality and length completely..
  6. Thanks for the write up Tom! Looks great :smile:
