225 Wheel Bearing Removal
Discussion in 'Suspension, Brakes, Wheels & Tyres section' started by Trophyboy, Oct 3, 2017.
  1. First time I've removed a megane front wheel bearing but does this part come out of the hub as well??
    Don't want to damage anything before beating it out?
    It's like an outer carrier but want to make sure first as i don't have a new bearing to check.
    Cheers 29f5338e0f7f8e63aa346d7495368f37.jpg 640cfb6d567f325b472ac59118fb9fd0.jpg
  2. If they are anything like the clio 182 hubs u need a press to remove and refit.
    Trophyboy likes this.
  3. matt e
    yeah that comes out
  4. Yeah that's half of the bearing race.
  5. Thanks fellas, just needed to double check first.
    Are they a press out job from the back?
  6. Yeah, although you could probably tap it out. I've never tried.
  7. Managed to get them out in the end.
    What I did was weld a bead all the way round the inner part of the bearing carrier and the heat generated from the weld made them just tap out using a chisel on the weld :grinning:
  8. When you refit new bearings, don't forgot they go in a certain way.
    One side has the magnetic pickup for the abs sensor, this faces inwards.
    Trophyboy and Mikey4410 like this.
  9. Is there an obvious way to tell which way they go? I am about to do this job. Cheers.
  10. yes it is, its the side with the protective cover when you open the box.
    Or place something metal against the seal and you will feel it stick.
