What have I done to my handbrake?
Discussion in 'Suspension, Brakes, Wheels & Tyres section' started by Hedge, Oct 5, 2017.
  1. Ok, for the first time I changed Rear Pads and front Discs and Pads.
    After a massive nightmare with one rear caliper refusing to wind in I eventually managed it and all seemed good. Wheels back on, took it for a spin. Brakes all good...
    Handbrake however. Doesnt do anything until its at its absolute max extension. Its almost like the bottom notches arent even attached to anything.
    What have a missed ? :-/ lol .
  2. is it not a self adjusting one? have you tried keep pumping it?
  3. I dunno if its self adjusting.
    Its a 2010 Mk3 RS250.
    I pumped the foot brake then took it for a spin, all seemed ok. Pulled back onto drive and then when I put handbrake on it so light and pulls almost vertical.
    I tried pulling and releasing it multiple times and pumping foot brake. I'll have to investigate more I guess :worried:
  4. Did you have your handbrake on when you removed and replaced the Pads?
  5. I know I has handbrake off when I did the driver side but I have a feeling I might have had it on for one point on the passenger side before I realised :worried:
  6. Ive fixed it. Im such a donut.
    Turns out I needed to start engine, press in pedal, pull handbrake, release pedal, press pedal, pull handbrake.. repeat about 12 times..
    then it tightened itself up.
    Thanks guys!
