225 Traction control light on
Discussion in 'Suspension, Brakes, Wheels & Tyres section' started by iiPaul, Dec 31, 2016.
  1. Just replaced both front wheel bearing and the traction control light is on and can't be turned on or off at the switch, is this a sign the bearing are round the wrong way [emoji23]
    There's not error message the dash when you click through
  2. Did you disconnect the wheel speed sensors from the wheels? Did you re-connect them and securely connect them to the wheels - a little clip they slot into...
    Sent from my SM-A300FU using Tapatalk
  3. Yeahh they're both clipped in properly I believe
  4. You might need CLIP or another decent diagnosis system to see if it's anything else... that's the only sensor I can think of that's attached to the wheel that might trigger an error. One of them might have failed at either the dismantling or reassembly...
  5. There were no problems or lights on until I replaced both wheel bearings, just wondering if the bearings were put in the wrong way round.. lol
