R26 Talk to me about front camber adjustment
Discussion in 'Suspension, Brakes, Wheels & Tyres section' started by Frimley111R, Sep 14, 2018.
  1. I heard from a lot of people that adding negative camber to the front can improve turn in. However, I have never done this or even looked into it, so...
    Can this be adjusted without changes to the suspension (i.e. adjustable new parts)?
    How much camber should I add?
    What are the pros and cons?
    I use my car a weekend toy and the odd TD so its not a daily driver.
  2. I don't think it can be done without adjustable top mounts.
    PureMS were working on some which a member was testing but I think they are back to the drawing board.
    Frimley111R likes this.
  3. Can't be done with standard suspension.
    Toe out can help with a quicker turn in and they do run some as standard.
  4. -Jamie-
    Need adjustable topmounts
  5. Powerflex do eccentric bottom bushes - has anyone experience?
  6. I have a set on my mk2, had quite a lot of problem with them turning while on trackdays, tightened them up to stupid tightness and still would move and had to keep readjusting them, in the end i notched the bracket to lock the fitting to stop it moving, since then no problem.
