Spa Francorchamps vs Megane RS
Discussion in 'Megane Media' started by -Jamie-, Oct 17, 2017.
  1. -Jamie-
    Some of the more interesting bits from Spa a couple weeks back, unfortunately one of my dampers started leaking and lost all its oil so I had no damping on the front right corner which made under brakes a bit wobbly and the Gast stuff interesting
  2. Good spot for the go pro , and great video, can't wait to get back over there.
  3. Nice video! Only just all 4 wheels off at Raidillon :wink:
    You spend the majority of your time in 4th, how much torque are you running!?!
    A real shame about the damper, what will you do? Rebuild or try something else?
    -Jamie- likes this.
  4. -Jamie-
    385lbsft, had some tuition at the Ring the day before and found using a higher gear and utilising the torque really helped hook the diff up.
    ASTs are going back to get serviced/rebuilt when I get some free time had to cancel donny at the end of the month which im quite gutted about
  5. Good advise. How did you find the Pagids?
    Also, what method did you use for mounting the GoPro its a great spot to mount it.
  6. -Jamie-
    Mega, properly happy with the brake setup now. Similar if not better stopping power than my old favourite XP10s but feel a lot better and modulation is nicer.
    Go pro is just on a suction mount on the pax window with some additional bits to get it to sit further into the cabin so you don't just get A pillar
