Rs250 bilsteins b14
Discussion in 'Car Parts For Sale' started by Cazper, Oct 11, 2018.
  1. For sale.still on car at the moment so can be seen working. Work a treat but moving to ASTs. Will get pics of them once i have taken them off.
    £595 Collected RG27 or can post at cost
    these are £900 from Demon Tweeks
    ride height adjustable
    some bumpf
    Bilstein B14 PSS Ride Height Adjustable Kits are an adjustable ride height system front and rear, with factory tuned, fixed rate damping. Bilstein's extensive motorsport experience and Original Equipment damper manufacturing has enabled them to produce a range of coilover suspension kits that are specifically designed for each application and suited perfectly for performance driving on the road.
    The B14 PSS Coilover Kit's gas pressurised damping has been optimised for fast road driving - good ride quality at low speeds, ultra stable at high speed, and suitable for everyday use. The triple C Technology used for surface coating gives long lasting corrosion resistance, and the round threads and special alloy spring plates enable easy height adjustment for years to come.
    • Bilstein's Mono-Tube damper technology
    • Triple C coated coilover housings for long lasting corrosion resistance and good looks
    • Round threads and special alloy spring plates for easy height adjustment
    • Designed, developed and tested for each application
    • Supplied with necessary bump stops
    • Excellent suspension travel retained - a must for decent handling on poor roads
    • German TUV certified, made in Germany
  2. Standard top mounts and how old?
  3. has top mounts which might be silver projects not sure, will get pics when they are off, as for age not sure as they were on the car when i purchased it, they were fitted last summer so might be a year or two old
