R26 Replacing air con compressor help
Discussion in 'Mechanical - Engine, Gearbox, Exhaust etc' started by Dale1uk, Jul 8, 2018.
  1. Hi guys, my climate control isn't working on my R26 so I've been doing some fault finding. The system is full of gas and the pressure switch is working correctly. There's no fault codes showing. I'm getting a switched 12v feed to the compressor when turning the air con on and off but the compressor clutch isn't kicking in so presume my compressor is shot.
    So a few questions
    Is the clutch on the compressor replaceable or is it just a case of replacing the complete unit?
    If I need to replace the compressor it worth picking up a used one and hope it lasts, or should I just bite the bullet and buy a new one?
    If I need to buy a new unit does anyone have any recommendations for a suitable one?
    Is any of the above works something thats easy enough to do myself, or is it definitely a garage job? (I'm fairly handy and usually do all my own works on my cars but the few times I have have worked on the Meg it's always been a bitch to work on!)
    Thanks in advance
  2. So I've been doing some digging and it would appear that the compressor clutch assembly can be replaced instead of replacing the complete unit. I'm hoping that I can replace the clutch with the compressor in place, or at least without having to disconnect the high and low pressure lines. I'll also check through the cars paperwork to find out when the aux belt and tensioner were last replaced and will replace them too if required.
    Here's a link to the replacement clutch assembly:
    https://www.autopartspro.co.uk/delphi-1750782
  3. You'll be lucky to get that changed with the pump in place, access is bad, but good luck trying.
