Removing bottom arms r26
Discussion in 'Suspension, Brakes, Wheels & Tyres section' started by Artt24, Oct 26, 2017.
  1. In the process of replacing and powder coating hub and hub carriers along with lower arms and replacing all bearings shocks springs etc, what is the easiest way to remove the lower arms as i cant seem to get at the long bolt that holds the arm on, was wondering how you guys have removed these.
  2. matt e
    have you removed the subframe the radiator sits on?
  3. I was hoping there was a way round having to do that
