1. Richardspeed10
    Richardspeed10 RSM Club Member
    Does anyone have any r26 lying around I’m trying to find out if mine are aftermarket or standard as the few I have seen are different to mine. Thanks
  2. yeah..could be the aftermarket eibach springs for R26..they are softer..
    renualt part number for genuine eibach front spring is...8200647852
  3. What softer than the original non lowering R26 suspension?
  4. yep..seen the spring rates somewhere on here.
  5. R26R
    Front - 14 mm/100 kg (Progressive)
    Rear - 16.2 mm/100 kg (Linear??)
    7.14kg/mm or 399.8 Ib/in or 70 N/mm
    6.17kg/mm or 345.5 Ib/in or 60.5 N/mm
    R26
    Front - 13.4mm/100 Kg (Progressive)
    Rear - 15.1 mm/100 Kg (Progressive)
    7.46kg/mm or 417.7 lb/in or 73.2 N/mm
    6.62kg/mm or 370.7 lb/in or 64.9 N/mm
    Eibach Pro-Kit
    Front - 37N/mm or 211.2 lb/in (Linear)
    Rear - 30N/mm or 171.3 lb/in (Linear)
    H&R Mono-Tubes
    Front - 60N/mm or 342.6 N/mm (Progressive)
    Rear - 43N/mm or 245.5 N/mm (Linear)
    H&R Spring Kit
    Front - 45 N/mm (Progressive)
    Rear - 30 N/mm (Linear)
    Gaz Gold
    Front – 425 lb/in or 74.4 N/mm (Progressive) - Requires confirmation
    Rear – 425 lb/in or 74.4 N/mm (Linear)
    Prima Springs
    Front - 37N/mm
    Rear - 30N/mm
    Cobra 20mm
    Front - 28N/mm
    Rear - 30N/mm
    Cobra 40mm
    Front - 26N/mm
    Rear - 28N/mm
    AST Sportline 2 (standard supplied rates)
    Front - 450 lb/in or 78.8N/mm
    Took a while. I posted them some time back, couldn’t find them for love na’ money. So went back to the original source.
    Source: Poobah, Meganesport.net
  6. wow..this was many years back.Poobah was one of the original members.
  7. Updated with Grams spring rates
    R26R
    R26
    Eibach Pro-Kit
    Grams
    Front - 50.2N/mm, 286lb/in, 5.1kg/mm
    Rear - 44.3N/mm, 253lb/in, 4.5kg/mm
    H&R Mono-Tubes
    H&R Spring Kit
    Gaz Gold
    Prima Springs
    Front - 37N/mm
    Rear - 30N/mm
    Cobra 20mm
    Front - 28N/mm
    Rear - 30N/mm
    Cobra 40mm
    Front - 26N/mm
    Rear - 28N/mm
    Source: Poobah + Pondman
    Awaiting a response from Cook Sport as to their specific set-up rates.
