R26 Removing dump valve
Discussion in 'Mechanical - Engine, Gearbox, Exhaust etc' started by D11nyd, Jul 14, 2018.
  1. I’d like to remove the dumpvalve fitted to my LY R26 as it does my head in after driving it for 5minutes!
    I’ve got hold of a second hand forge pipe to replace the T piece where the dump valve goes, is it just a case of removing the blank and fitting an original or if I can’t source one order an uprated forge one?
    Will The power feel different without the dump valve or will it run better with the forge recirculating valve?
  2. matt e
    yeah just remove the t hose and fit the recirc valve. and connect the small boost hose to the recirc vale.
    the power shouldn't feel different
  3. Ok mate cheers
