R26 2 piece brakes and brembo callipers
Discussion in 'Car Parts For Sale' started by Korky, May 3, 2018.
  1. Ideally I would like to sell this as a kit.
    I have 2 piece 330mm reyland bell and rotor setup that has covered around 3K road miles £300
    Mintex 1144 pads again 3k road miles £40
    And r26 red brembo callipers around 60k £200
    Or £500 as a package
    Collection from Middlesbrough or can post if needed
  2. Do discs come with spacers ?
    And also are you open to offers ?
  3. Yes to both, send me a PM
  4. Pm sent.
  5. Only got the bells from the full setup left, will include calliper spacers and bell to rotor bolts.
    Order a fresh set of rotors and you have a cheaper 330mm brake setup!
    £150 collected, postage can be arranged if needed
  6. Hi, do the bells also include the longer caliper bolts as I believe the OEM ones are too short with the spacers installed?
  7. Hi mate, with the 330’s you run the original bolts, anything bigger is when you need to go longer bolts
  8. Reyland and Godspeed both say that longer bolts are required so I’ll have to grab some from them. Would you take £100 posted for the bells and spacers?
  9. Sent you a pm
  10. Still got the bells
  11. I still have these if anyone is interested
  12. Do you still have tbe calipers. I assume they fit straight onto a 225 f1?
  13. These still for sale ?
  14. just put the mk3 brembos on.Similar money for better results.
  15. As in callipers and disc ?
  16. Yes, so you can go from 312mm disc's to 340, or 355mm if you really want, but i found the 340mm setup on my mk2 was superb and the pads are cheaper for the mk3's.
    https://rsmegane.com/threads/big-brakes-on-a-225.12178/
  17. this is it.certainly a great upgrade.Only really need it though for mega fast road or track.
    My mk2 set up with xp8`s and bespoke cooling ,can take all abuse thrown at them.
  18. See someone was selling a hole set up and I was interested in buying it but you have to have the disc re drilled don’t you ?
  19. Yes but it’s not a big deal to get it done. Cost me £18 a disc
  20. CJ_RSport
    CJ_RSport RSM Moderator
    Ive bought them :wink:
  21. yes you need to get them drilled but shouldn't cost much, will be well worth doing
