225 oem oil cooler?
Discussion in 'Mechanical - Engine, Gearbox, Exhaust etc' started by pervertedmonk, Sep 18, 2018.
  1. Hi. may be a silly question but does the 225 have an oil cooler as standard ?.
    cheers.
  2. Yes they do, its behind the oil filter and cooled/heated by engine coolant.
  3. Could by any change these breakdown and allow water in the oil ?. is it a ball ache to replace?.
    im just trying to cover all angles before i admit defeat and go for the head gasket.
    i have already replaced the thermostat gasket.
  4. Yes they can leak, one easy way to tell is to remove both coolant pipes and join them together, then run it, if it is gone there will be oil leaking out of one of the pipes.
    just need to remove the under tray, oil filter off and then the 32mm nut, don't forget the turbo is also water cooled, just saying :grin:
  5. Hi .
    Cheers for the info. much appreciated. ill try the cooler first.Then the turbo...
