1. This site uses cookies. By continuing to use this site, you are agreeing to our use of cookies. Learn More.
OEM equivalent suspension and steering components *links inside*
Discussion in 'Suspension, Brakes, Wheels & Tyres section' started by Gray, Aug 6, 2014.
  1. richmeg
    richmeg
    484
    11
    Car:
    Meg 225 Cup
    Awesome thread! Just about to refresh all my steering/suspension parts . . . its never been right since I owned it.
    So all available except from the inner tie rods where no option but to buy from Renault.
    Are there any updates in terms of rebuilding the wishbones i.e. aftermarket bushes?
    Can someone post a link to the ball joints as the eurocarparts one in the thread above doesn't work.
    Or have we found anywhere that supplies the correct OEM whole wishbone?
    Thanks,
    Rich
  2. charlie1984
    charlie1984
    706
    4
    I'd be interested in what bushes í can replace... I cant seem to find any answers on what bushes can be changed...
  3. richmeg
    richmeg
    484
    11
    Car:
    Meg 225 Cup
  4. charlie1984
    charlie1984
    706
    4
    Ooo powerflex have a câncer adjust bolt like they do for the clio...
  5. charlie1984
    charlie1984
    706
    4
  6. -Jamie-
    4,137
    680
    Car:
    RS250+ Cup
    Must be a mistake AFAIK the setup on the Megane doesn't allow camber adjustment via bolts?
    Actually they might be for the non RS Megane
  7. charlie1984
    charlie1984
    706
    4
    Ah ok thought í found something new lol
  8. richmeg
    richmeg
    484
    11
    Car:
    Meg 225 Cup
  9. Gray
    Gray RSM Moderator
    551
    9
    Car:
    Megane r26
  10. charlie1984
    charlie1984
    706
    4
    Are the vibra technics ones not tirares in any way?
  11. Naith
    1,882
    85
    Car:
    TDK
    have the original links expired Gray? Few seem to direct to a dead page.
  12. richmeg
    richmeg
    484
    11
    Car:
    Meg 225 Cup
  13. Gray
    Gray RSM Moderator
    551
    9
    Car:
    Megane r26
    hmmm... if you put your reg no. in does it direct to the parts?
  14. Naith
    1,882
    85
    Car:
    TDK
    I didn't actually see the option for that mate... I did look. (As i'm after the horizontal droplink for mine)
  15. richmeg
    richmeg
    484
    11
    Car:
    Meg 225 Cup
  16. Steven878
    Steven878
    590
    11
    Car:
    R26
    Has anyone purchased front strut top mounts from this website? There seems to be a couple different options...
  17. richmeg
    richmeg
    484
    11
    Car:
    Meg 225 Cup
    I'm also interested in this . . . or other sources to buy reasonably priced OEM or aftermarket top mounts?
    Are you just changing the fronts or doing something with the rear as well?
  18. Steven878
    Steven878
    590
    11
    Car:
    R26
    I'm replacing all the shock absorbers, fitting cooksports springs new front top mounts...
    iv just this minute emailed ads to see how much the oem ones cost.
  19. richmeg
    richmeg
    484
    11
    Car:
    Meg 225 Cup
    Ok cool . . . I'm just trying to eliminate some knocking/creaking noises which have been around for a WHILE . . .
    Suspect it could be the front drivers side top mount so just replacing that and the other side first.
    Let us know on the cost of the OEM ones.
    Cheers.
  20. manifold
    manifold
    139
    1
    Car:
    RS 225
    Looking at refreshing my own 225 - she's an 08 with 168k KM on the clock.
    Based on the thread,
    L&R track rod
    2*link stabilizers
    2*control arm bushes
    2*ball joints (from other thread)
    and i'll get 2 hub bearings separately.
    Anything I've missed or should do if I'm doing the above?
  21. Mark.
    Mark.
    441
    13
    Car:
    Megane 225
    It probably will be them, mine sounded like a budgie according to wife.
    Though i liked to think it sounded like a rally car with the way they chirp !
  22. Gray
    Gray RSM Moderator
    551
    9
    Car:
    Megane r26
    Sounds about right!
  23. Naith
    1,882
    85
    Car:
    TDK
    I ordered the other day and the part arrived with a courier today. Good service.
  24. manifold
    manifold
    139
    1
    Car:
    RS 225
    ty :smile:
  25. Just-that-ek
    Just-that-ek
    665
    13
    Before I go ahead with purchasing these is everything right on there..?
    Will be getting the inner tie rods from Renault
  26. Gray
    Gray RSM Moderator
    551
    9
    Car:
    Megane r26
    Looks good to me.
    I wouldn't buy the shock absorbers from them, they're about the same money from Renault.
  27. Just-that-ek
    Just-that-ek
    665
    13
    Nice one thanks, I'll get them ordered now
  28. richmeg
    richmeg
    484
    11
    Car:
    Meg 225 Cup
    I thought the lower (track control) arms were not suitable for the 225/R26 and only normal Megs as they are missing certain bits? Check earlier on in the thread . . .
    Most people it seems rebuild their original arms with new ball joints and bushes, more info. on this earlier on in the thread also.
    I ended up ordering top mounts from Renault as I read a few stories of alternative manufactured parts failing after a short while (not sure which though).
    The shocks from Renault are about £50 each so those are cheaper but whether KYB replacements are any good I'm not sure.
  29. david h
    david h
    150
    0
    Car:
    R26 280 bhp sold
    How hard is the rear bush on the front arms to change, is it a press in fit and arm off job? ,my front bush and ball joint are fine, cheers
  30. steering
    steering
    105
    9
    Hello,
    Does anybody have the part numbers of OEM shock absorbers for megane 250 cup?
    Thanks in advance
  31. krrizz
    krrizz
    16
    0
    Car:
    225 FF
    Great thread – I Have the same on Polish forum :smile:
    I just would like to add that front Ball joints fits from Espace III part no. 6025308155 for example Febi part no. 22279, TRW JBJ732
    Top mounts also fits form TRW - part no. JSL290 (with bearing)
    Hub Bearings - INA BK4520 (only a bearing)
    Axle Mounting Bush - Febi 31395
  32. Gray
    Gray RSM Moderator
    551
    9
    Car:
    Megane r26
    Great info, I will add that to the first post.
  33. Nunez20
    Nunez20
    310
    10
    do these parts all fit a r26 or just a 225?
    I know when I put my reg into the parts section for say the link stabilizer it shows a few one with normal suspension and one with sports and then the one linked?
    just want to check before I order anything
    thanks in advance
  34. TimR26
    446
    35
    Car:
    Forged LY R26
    I ordered the TRW twist links and ball joints using these part numbers and they definitely fit.
  35. L-1011
    L-1011
    944
    63
    If your meaure your droplink I'll confirm if it's for the part number listed!
  36. L-1011
    L-1011
    944
    63
    As per the parts listed on here, the droplinks measure c290mm centre to centre
  37. charlie1984
    charlie1984
    706
    4
    Looking at those mister auto links... Anyone used the lemforder stuff?
  38. not normal dan
    not normal dan
    917
    25
    Yeah I used all lemfordner when refreshing my old 182 trophy, iirc they produce the OEM BMW stuff
  39. charlie1984
    charlie1984
    706
    4
    Cool... I'm looking to replace stressing arms and all sorts and it seems there stuff is much cheaper than the renault stuff...
  40. .Stevo.C.
    .Stevo.C.
    525
    3
