Megane R26 wanted
Discussion in 'Wanted' started by Keith lannigan, Sep 4, 2018.
  1. Anyone selling any R26s cash waiting for the right car
  2. My Liquid yellow R26 is for sale, just not advertised properly yet.
    Drop me a pm if you are interested
    Current spec of mine as it stands is as follows...
    Engine:
    Forge Recirc
    Silicon turbo Intake
    ITG Induction Kit
    Pro Alloy Front mount Alloy Intercooler
    Forge Hard Pipes
    3" RS Tuning Decat
    KTEC 3" Exhaust
    VibraTechnique Mounts
    RS Tuning Map
    630cc Injectors
    Custom Oil Catch Can
    Clio 1*2 Crank Pulley
    197 Cup Racer Cambelt Cover
    Air Con Delete (4PK810SF [Gates/optibelt])
    Deatschwerks 65C (265L per Hr) Fuel Pump
    Custom double braided SS PTFE core fuel lines with black AN6 fittings, check valve and 30 Micron filter
    Custom fuel rail and sender unit
    ARP Conrod Bolts (216-6301 [M9])
    Transmission:
    TTV Single Mass Flywheel
    R26r Clutch
    Slave Cylinder + Fluid
    2 x R26 New Driveshafts
    Short Shift
    Body / Exterior:
    R26R Spoiler
    Skoda Fabia Splitter
    Stubby Ariel
    Bonnet Strut Kit
    Liquid yellow mirrors
    Black Insert Xenon's
    New Style Renault Badge
    Silvertec Indicator Bulbs
    OSRAM 501 LED 6000K W5W Sidelight bulbs
    LED Rear Number Plate Lights (Xenons Online)
    New Genuine Front Grills
    Genuine Front Mud Guards
    R26R Fog Light Blanks
    Interior:
    White LED Bulbs
    Black Interior Panels
    Pioneer Double Din
    Leather Arm Rest Centre Console
    Snappy Steering Wheel Retrim
    Snappy Gear Stick Gator Retrim
    Snappy Gear Knob Retrim
    Recaro’s with leather rear bench
    Battery Relocation
    Suspension:
    BC Racing RA Coilovers 7kg F 7kg R 20mm
    BC Racing RA Coilovers Side Extender
    Drop Link Stabilizer (X2) [TRW] {BMW E36 M3 427BM0010}
    Anti Twist Link Stabilizer (X2) [TRW]
    Inner Tie rod (X2) [TRW]
    Front wishbone bushes (Powerflex Black Series)
    Rear wishbone bushes (Powerflex Black Series)
    Front Anti Roll Bar (Powerflex Black Series)
    Rear Axle bushes (Powerflex Black Series)
    Grease Nipple Bolts For Hub Bearings
    Geometry Setup (10 Mins Toe Out, 1.5 Degree Camber)
    Wheels / Tyres:
    Pro Race 1.2 Gloss Antheracite 18x8 ET45
    Michelin Pilot SuperSport 235/40/18 95Y
    Stud Conversion M14x1.5
    Brakes:
    New Brembo Megane 250/264/275 calipers
    New 250 brembo HC discs
    Performance friction Z rated pads
    197 Rear Discs
    Genuine Rear Pads
    Braided lines (HEL, SS Fittings)
    RBF 660 Brake Fluid
    Stainless Steel Brake Pin Kit
    Stainless Steel Brake Nipple Kit (X4)
    Servicing since i have owned it:
    Millers Nano 5W40 Engine Oil + Renault Oil Filter + AP10 Gold Magnetic Sump Plug (30/03/2016)
    Renault NGKR Spark Plugs (30/03/2016)
    Bosch 21" Front Aero Wiper (02/04/2016)
    Bosch 18" Front Aero Wiper
    Motul Nano 75w80 Gearbox Oil (05/04/2016)
    Genuine Thermostat (05/04/2016)
    Genuine Renault Auxillary Belt kit (05/04/2016)
    Genuine Rear Exhaust Mount (X2) (05/04/2016)
    Engine Oil & Filter (Mark Black) Millers Nano 5W40 (22/10/2016)
    Genuine Cambelt & Water Pump (Mark Black) (22/10/2016)
    Engine Oil & Filter Millers Nano 5W40 (06/03/2017)
    Battery (5 Year Warrenty) (15/04/2017)
    R26R Washer Bottle (15/04/2017)
    Renault NGKR Spark Plugs (28/12/2017)
    5L Type D Coolant (28/12/2017)
    ELF Evolution 900 SXR 5W40 Engine Oil + Renault Oil Filter (28/12/2017)
  3. How do I pm u mate
  4. You cant at the moment, not enough posts, but if you "quote" his post he will get an alert
  5. I don’t think I can yet mate with not having enough posts can u pm me if possible
  6. Sent, did you get it ???
