Hi, Really stuck and in need of major help. I am trying to replace the lower swivel bearing, I have the upper and lower bolts removed but the hub won't come out. The top is free to move but the bottom is stuck in place. Any help would be amazing. Thanks
Hi Ben Put the bolt back in the bottom about 5-6 turns and give it a good smack with a hammer, you only need to knock it in about 4-5mm.
Thanks that worked except I had to use a sledge hammer some took abuse. All done and back together now.
