Liquid Yellow Megane R26
Discussion in 'Cars For Sale' started by Korky, Oct 4, 2018.
  1. For sale is my liquid yellow r26, I have owned the car nearly 4 years, however I am about to buy my first home and can no longer justify this being a second car.
    The spec is as follows:
    Mileage 75k
    Engine:
    RS Tuning map - 307hp / 315ft/lb
    Forge Recirc
    Silicon turbo Intake
    ITG Induction Kit
    Pro Alloy Front mount Alloy Intercooler
    Forge Hard Pipes
    3" RS Tuning Decat
    KTEC 3" Exhaust
    VibraTechnique Mounts
    RS Tuning Map
    630cc Injectors
    Custom Oil Catch Can
    Clio 1*2 Crank Pulley
    197 Cup Racer Cambelt Cover
    Air Con Delete (4PK810SF [Gates/optibelt])
    Deatschwerks 65C (265L per Hr) Fuel Pump
    Custom double braided SS PTFE core fuel lines with black AN6 fittings, check valve and 30 Micron filter
    Custom fuel rail and sender unit
    ARP Conrod Bolts (216-6301 [M9])
    Transmission:
    TTV Single Mass Flywheel
    R26r Clutch
    Slave Cylinder + Fluid
    2 x R26 New Driveshafts
    Short Shift
    Body / Exterior:
    R26R Spoiler
    Skoda Fabia Splitter
    Stubby Ariel
    Bonnet Strut Kit
    Liquid Yellow Wing Mirrors
    Powdercoat Under Brace
    Black Insert Xenon's
    New Style Renault Badge
    Silvertec Indicator Bulbs
    OSRAM 501 LED 6000K W5W Sidelight bulbs
    LED Rear Number Plate Lights (Xenons Online)
    New Genuine Front Grills
    Genuine Front Mud Guards
    R26R Fog Light Blanks
    Interior:
    Recaro’s Trendlines, (drivers side has the usual small tear on bolster
    Leather Bench
    Leather Doorcards
    White LED Bulbs
    Black Interior Panels
    Pioneer Double Din
    Leather Arm Rest Centre Console
    Snappy Steering Wheel Retrim
    Snappy Gear Stick Gator Retrim
    Snappy Gear Knob Retrim
    Battery Relocation
    Suspension:
    BC Racing RA Coilovers 7kg F 7kg R 20mm
    BC Racing RA Coilovers Side Extender
    New Drop Link Stabilizers [TRW]
    New Anti Twist Link Stabilizer (X2) [TRW]
    New Inner Tie rod (X2) [TRW]
    Front wishbone bushes (Powerflex Black Series)
    Rear wishbone bushes (Powerflex Black Series)
    Front Anti Roll Bar (Powerflex Black Series)
    Rear Axle bushes (Powerflex Black Series)
    Grease Nipple Bolts For Hub Bearings
    Geometry Setup (10 Mins Toe Out, 1.5 Degree Camber)
    Wheels / Tyres:
    Pro Race 1.2 Gloss Antheracite 18x8 ET45
    Michelin Pilot SuperSport 235/40/18 95Y
    Stud Conversion M14x1.5
    Brakes:
    New Brembo Megane 250/264/275 calipers
    New 250 brembo HC discs
    Performance friction Z rated pads
    197 Rear Discs
    Genuine Rear Pads
    Braided lines (HEL, SS Fittings)
    RBF 660 Brake Fluid
    Stainless Steel Brake Pin Kit
    Stainless Steel Brake Nipple Kit (X4)
    Servicing since i have owned it:
    Millers Nano 5W40 Engine Oil + Renault Oil Filter + AP10 Gold Magnetic Sump Plug (30/03/2016)
    Renault NGKR Spark Plugs (30/03/2016)
    Bosch 21" Front Aero Wiper (02/04/2016)
    Bosch 18" Front Aero Wiper
    Motul Nano 75w80 Gearbox Oil (05/04/2016)
    Genuine Thermostat (05/04/2016)
    Genuine Renault Auxillary Belt kit (05/04/2016)
    Genuine Rear Exhaust Mount (X2) (05/04/2016)
    Engine Oil & Filter (Mark Black) Millers Nano 5W40 (22/10/2016)
    Genuine Cambelt & Water Pump (Mark Black) (22/10/2016)
    Engine Oil & Filter Millers Nano 5W40 (06/03/2017)
    Battery (5 Year Warrenty) (15/04/2017)
    R26R Washer Bottle (15/04/2017)
    Renault NGKR Spark Plugs (28/12/2017)
    5L Type D Coolant (28/12/2017)
    ELF Evolution 900 SXR 5W40 Engine Oil + Renault Oil Filter (28/12/2017)
    I will also have it serviced before it goes.
    I a folder full of receipts for all parts on the car, totalling around £12k
    The car is located in Middlesbrough, the price is £7k.
    Feel free to text me on 07850377154, or I can take calls anytime after 16:15.
    Kirk
    Mariusz, Brigsy, Poppaboost and 2 others like this.
  2. Poppaboost
    Poppaboost RSM Club Member
    Awesome spec, glws
    Korky likes this.
  3. Alex Essex
    Alex Essex RSM Club Member
    Love that
    Korky likes this.
  4. Stunning
    Korky likes this.
  6. Looks great, hope Ian gets on with it.
    Cazper likes this.
  7. He is chuffed to bits
    Feirny likes this.
  8. Wow very nice, look forward to seeing it.
    Cazper likes this.
  9. Cbulmer
    Cbulmer RSM Club Member
    Awesome spec list. Lucky buyer!
  10. Such a cool car!
  11. Doh!
