Jingling noise.
Discussion in 'Megane Discussion' started by Andy_C, Oct 20, 2013.
  1. I'm getting a jingling noise coming from the front drivers side suspension of my R26. Does anyone know what it could be?
    It's driving me nuts, I've had it on a lift and checked every joint and bush, it all seems tight. The only thing I think it might be is the hubs, they tend to feel sticky now and then, I've got a pair of refurbed ones which are due to be fitted soon. My car has only done 50,000. Any help or ideas would be great.
  2. Could just be a really badly designed and engineered car.
  3. what kind of jingling noise is it... is it a squeak everytime you go over a bump or is it a constant squeaking/jingling noise from driver side, mainly at start up? how old is the car and has it had belt/water pump change?
  4. have you checked the lower hub bolt on the swivel bearing as they can loosen and the washer rattles
  5. It sounds like a little bell jingling when ever the front drivers side wheel goes over a bump or pot hole.
    The car is only on 51,000 miles and it's a 57 plate.
    I'll check the bolt your motioned.
  6. Top mount?
  7. Markblack@MRS
    Markblack@MRS RSM Trader
    Lower hub bearing bolt,
    The one behind the disk, it may be the washer jingling
  8. Will defo get this looked at. Thanks mate.
