265 How much brake fluid do I need?
Discussion in 'Suspension, Brakes, Wheels & Tyres section' started by Frimley111R, Feb 2, 2016.
  1. I am fitting braided hoses and so will be changing the fluid too. I already have Motul RBF660 Dot 4 spec fluid but can't remember how much I need to buy.
  2. -Jamie-
    1l will be enough
  3. If you're doing the lines yourself, how much fluid you need also depends on how much you let pee out whilst swopping the lines over.
  4. ^^^^what he said^^^^
  5. also note it's incredibly easy to let air into clutch feed pipe on master reservoir as it's located half way down the reservoir side but hidden behind engine air filter container (silly design) meaning before the reservoir is empty there's already air in clutch line, that said should really bleed clutch at same time, quite easy, keep same fluid in both domains.
  6. Ok, not doing the fluid myself and it will be the same guy who changed the fluid last time.
  7. Good brake maintenance keeps a firm pedal and trimming out any slack on the rear TRW self-adjusters which can give a constant pedal travel issue.
  8. So are you doing the lines but not the fluid?
