250 Check Injection Light And Esp Fault Code Help
Discussion in 'Mechanical - Engine, Gearbox, Exhaust etc' started by JordanJ1035, Nov 11, 2018.
  1. Hi guys, as you can guess from the title my CIL & ESP light came on the other night,
    The lights popped on after some pretty hard driving, they then kept coming on over the next couple of miles when i was driving steady at around 2500-3500RPM
    I had no power loss or performance issue when the lights came on etc even when i was driving hard.
    I plugged in and it came up with the following codes
    DF1058 Inlet Pressure Consistency, Value Outside Tolerances (memory)
    DF1089 Turbocharging Pressure Coherence, Implausible Signal (active)
    Anybody had anything to do with these codes or able to help shed any light on the codes and where to start?
    Thanks in advance!
