225 Check abs/esp
Discussion in 'Suspension, Brakes, Wheels & Tyres section' started by dannyboy101, Dec 26, 2017.
  1. Ive been having this come up on and off. Finally narrowed it down. It only happens when you turn right past about 45 degrees if that makes sense.
    Any idea what it could be? The car is also pulling to the left if that helps.
    Most of the front suspension is new.
    Car is a ph2 225 06 plate.
  2. Probably the ABS sensor. Might be worth pulling it out and wiping it down and make sure it sits correctly. (follow the black cable that comes from the mid/top of the wheel arch as thats the ABS cable and remove the bottom end from the hub). Make sure its not snagging and put it back.
    When its back in, turn the wheels full lock a few times and it should clear it all.
    idontknow likes this.
