250 Bonnet lifting not straight?
Discussion in 'Exterior & Bodywork' started by Sgwads, Jun 27, 2017.
  1. Hello all
    My 250bonnet is not sitting square at all
    It is slightly higher on passengers side so it doesn't sit perfectly flush with headlight.
    I can push the bonnet down and it sits perfect but the catch seems to move up and down when bonnet in place. Is this normal ?
    How do you adjust the bonnets? As it seems there 2 bolts under the bonnet then 2 at the side.
  2. Did you ever get this sorted mate as ive just noticed mine is the same and makes a crashing noise when hitting bumps
  3. Slightly out of line panels is normal? It's a Renault ... :tongueout:
  4. Hahaha very true matey
  5. -Jamie-
    Mine was the same, so I fitted aerocatches [emoji23]
