275 Best place to buy OEM replacement discs and pads for 275 Trophy?
Discussion in 'Suspension, Brakes, Wheels & Tyres section' started by Lewis, May 11, 2018.
  1. As above please gents, mine are shot and need replacing before it's MOT.
    Are the rear discs a nightmare to change?
  2. Try Kamracing.co.uk for the discs. Rears are easy, just need a few basic tools inc. torque wrench.
  3. The rear calipers wind in and not push in. You need a 36mm socket to take the hub nut off but it needs to be a thin wall otherwise it don't fit inside.
  4. Ok thanks.
    Are there any two piece discs which are worth a try?
    Reyland do some which look to be pretty decent.
  5. -Jamie-
    Waste of money and time getting 2 piece discs.
    Plain Brembos are all you will need.
    Search 09.A752.11 on eBay and buy the cheapest ones, IIRC the ones from Germany are under £130 quid.
  6. Anyone know the part number for the rear discs as well?
  7. I went for the groved version (09.A752.21) of what Jamie quoted, was the same price.
    There is not an equivalent for the rear that I could find when looking
